neutral light on & wont start w/o brake lever pulled
Old Apr 30, 2004 | 08:22 PM
deerchooper's Avatar
Default neutral light on & wont start w/o brake lever pulled
i looked every where and i cant find the problem. my neutral light is on but it wont start unless i pull the brake lever in. it did it before i installed cdi.
any ideas would be appreated!
____________
02 650p
nyroc muffler
155f/158r jets
super snorkle
dynatek cdi
epi black
700p drive spring
warn 2000
plow
Old Apr 30, 2004 | 09:01 PM
Nightryder888's Avatar
its probably a bad neutral sensor
Old May 1, 2004 | 07:54 PM
doesnt the neutral sensor also make the neutral light come on? if the neutral light works shouldnt the starting system work to?
___________________________
02 650p
nyroc muffler
155f/158r jets
needles shimmed .033
3 1/2 turns on pilots
super snorkle
dynatek cdi
epi black
700p drive spring
warn 2000
plow
Old May 1, 2004 | 08:13 PM
nyroc's Avatar
the neutral light proves that the neutral switch works. It does not prove that the neutral starter relay works. It is to the left of the CDI.
starting it with the brakes pulled proved that the brake switches work. It also proves that the brake starter relay works. It also proves that the main starter relay works. It also proves that the starter works.
You guys gotta have a manual to fiddle with electrical probs.
The brake starter relay looks like the exact same kind of relay, but it is between the heavy crossbar and the seat catch crossbar. I think those are the only two frame crossbars that are on top and readily visible when the seat is off.
Swap them and see if it makes a difference. See if there are bad fuses, damaged wires and stuff.
supermanotorious
Mar 12, 2021 11:02 PM
Steven Bandemer
Jun 9, 2015 08:50 PM
jayking232003
Jun 9, 2015 02:54 PM
1000gade
May 27, 2015 12:37 PM
CanadianViking
Feb 16, 2001 11:56 AM
