need sprocket changes...badly!!
Old May 1, 2004 | 09:23 PM
tbsleeper's Avatar
Default sprocket changes
well i want to change my sprockets badly right now so i need some help. i love torque but the amount my tb is makin is ridiculous!! if im on pavement i cand just blip the throttle and it will wheelie! i can bearly holeshot because it will pull a little wheelie on the dirt and just put a big roost down! so i want to gear for more speed and loose a little on the bottom. can someone tell me what sprockets to change to on the fron and rear? and will i need to change the chain?
by the way...iiim backkkkk!![img]i/expressions/face-icon-small-smile.gif[/img]
Old May 1, 2004 | 09:41 PM
Bing's Avatar
Super Quad Patrol
Smokes meat all the time!
Default need sprocket changes...badly!!
replace the chain,,,,,,the front sprocket,,,,and go 1,2,or 3 teeth smaller in the rear
replace all three at the very same time
Old May 1, 2004 | 09:46 PM
tbsleeper's Avatar
o definetly gonna do all at the same time. so u say go up 1 in front down like 2 out back? can someone tell me how many teeth are on back? i no its 11 in front.
Old May 1, 2004 | 09:52 PM
Bradracer18's Avatar
one in front is equal to 3 in rear
Old May 1, 2004 | 10:37 PM
On my old sport I always ran a 13/34 set up, I had quite a bit of power though, you may look into a set up close to that, probably more like 11or12/34.
Old May 1, 2004 | 10:52 PM
tbsleeper's Avatar
well i def wasnt gonna go to ten. maybe a 12/34 will be good. does anyone know the stock rear amount of teeth?
Old May 1, 2004 | 11:06 PM
tbsleeper's Avatar
well now that im looking for sprockets i cant find them anywhere. hotseat is really expensive, rockymountain only has sprockets for 99 trailblazers and scrambler 250 86's?? so does anyhone know wehre i can get some sprockets for like 30 bucks all together?
Old May 1, 2004 | 11:08 PM
you better plan on paying some money for a good set and they will last you forever
Old May 1, 2004 | 11:41 PM
2manytoys's Avatar
Your 02 TB has 11/38 sprockets. If you want more top end then run a 36t or 34t rear. The 34t may be to much loss of bottom end but a big gain in top. You can get sprockets from your polaris dealer or go to dennis kirk. Dennis kirk has tons of parts for every make and model. A good rear sprocket will cost about $30.
www.Denniskirk.com
Old May 2, 2004 | 12:03 AM
Hozed's Avatar
i dont know why everyone is makin this out to be so difficult... bump up 1 tooth in the front... and thats it... you can get a front sprocket for 11-20$... you dont need to change them all at the same time unless everything is VERY worn out...
