removing clylinder head help
Old May 1, 2004 | 09:57 PM
thewayout420's Avatar
Default removing clylinder head help
i wanted to inspect the top of my piston,so i took the head off.i didnt drain the antifreeze and when i took it off antifreeze ran down between the piston and the cylinder walls,is this bad?the top of my piston is black and its also pitted,is thhat normal?thanks for the help..
Old May 1, 2004 | 10:14 PM
tbsleeper's Avatar
dont know about the antifreeze but it looks as if were sanded and it is black crusty stuff, thats how mine was and i think that that means its too lean. been asking this for a long time, whats the black crusty stuff? does that mean its rich or lean??
Old May 1, 2004 | 10:17 PM
Bradracer18's Avatar
The black stuff is just a carbon build up....you don't judge how lean/rich your quad is running by how the piston looks, keep checking the spark plug to decide....the antifreeze should be fine, I don't think any can seep anywhere, try to blow out what you can with an air gun.
Old May 1, 2004 | 10:20 PM
thanks
Old May 1, 2004 | 10:21 PM
tbsleeper's Avatar
you can probably pull the pull starter with the head off to try to get it all worked out. i do this with my nitro rc car when its flooded and when put afterun oil in it.
Old May 1, 2004 | 10:25 PM
BeltDrive's Avatar
You also have a crankcase drain plug you can take out if any did get into your crankcase.
Old May 1, 2004 | 10:26 PM
ok thanks,ill take out the plug once i find it [img]i/expressions/face-icon-small-smile.gif[/img]
Old May 1, 2004 | 10:31 PM
BeltDrive's Avatar
there are three plugs under three. One is your recoil drain One is your counter balencer drain and one is your crankcase drain. It is the one forward in the middle of engine.
Old May 1, 2004 | 11:18 PM
cool thanks..
Divergent12
Dec 30, 2017 08:33 PM
toonces
Aug 5, 2015 05:55 PM
bpegram84
Jul 22, 2015 08:15 AM
bpegram84
Jul 22, 2015 08:12 AM
Desimation2k8
Jul 17, 2015 12:37 AM
