Bayou 300 revving?
Old May 3, 2004 | 12:49 AM
venforcer's Avatar
Default Bayou 300 revving?
My wife has a 1991 bayou 300 and when you let off the throttle it keeps revving about 1/3 throttle for about 5 sec. and slowly backs off to normal idle. I checked to make sure the cable isn't sticking and the throttle plate actuator is resting on the idle adjuster screw. Everything is fine there. Any input would be greatly appreciated.
Old May 3, 2004 | 12:57 AM
AlaskaBayouGuy's Avatar
maybe the slide in the carb is sticking??
Old May 3, 2004 | 01:43 AM
venforcer's Avatar
Thanks, I'll check that in the morning.
Old May 3, 2004 | 02:32 AM
Mohawk's Avatar
You could also have an air leek between the carb and the head.That will make it reve also.If it popping any when you let off the throttle than that whould also be an air leek.So look at that also.
Old May 3, 2004 | 03:25 AM
Customfabandweld's Avatar
Ditto, Mohawk.
Old May 6, 2004 | 12:14 AM
venforcer's Avatar
Just thought I would let everyone know that I fixed the revving problem. I took the air screw out and the o-ring on it was shreaded, causing too much air to get in through the threads on the needle. Put a new o-ring on it , screwed it out at two turns and it runs perfect. Thanks for all the info guys. I checked all those things first.
cswiger
Polaris Side by Sides
12
Oct 5, 2015 03:34 PM
bvolks
Sep 13, 2015 12:57 PM
Minimod
Sep 10, 2015 09:20 PM
Minimod
Sep 10, 2015 08:03 AM
rcappie4
Sep 9, 2015 07:04 PM
