Mountain climbin 500 Sportsman.. question?
Old May 3, 2004 | 01:34 AM
Ragged's Avatar
Default Mountain climbin 500 Sportsman.. question?
Well you guys have probobly been ask a million times...but ...What simple mod will give me the most power in low gear?? Im always climbim the steep stuff and realy havent had any problems yet.... but you can always use a bit more HP and torque on those long narly climbs!
Ragged
Old May 3, 2004 | 01:36 AM
simster570's Avatar
if you do the climbing with your scramblers, a cheap and easy way would be a gearing change. you can go further with it and get a low-end pipe, low end clutching, gearing change, and a K&N for more power everywhere.
If you climb with sportsmans, or anything with shaft drive, you cant make gearing changes.
Old May 3, 2004 | 02:47 AM
Ragged's Avatar
I do almost all the climbing with the Sportsman....Would a differant helix angle help? or lighter weights?
How much will a pipe and air filter give a 4 stroke?
Thanks
Ragged
Old May 3, 2004 | 02:52 AM
BigBadScrambler's Avatar
Get yourself a Heelclicker clutch kit for that Sportsman. You arent going to see any real gains from a K&N, just the fact that you wont have to buy a new air filter ever again. A pipe will give you a little more low end torque, but nothing astonishing. You best bet would be a clutch kit, like the Heelclicker which seems to work best with the utility machines
Old May 3, 2004 | 09:26 AM
mudmaster250's Avatar
dont change your gearing on your scrambler. that will only bring trouble (asuming it is 4x4) that will mess up the difference between the front and rear tires.
MooseHenden
Family ATVing Photos
Oct 5, 2015 08:14 AM
bigred20653
Oct 2, 2015 10:05 AM
mark23
Oct 1, 2015 09:57 AM
Nosniborpapa
Sep 19, 2015 07:07 PM
bigred20653
Sep 19, 2015 02:11 PM
