Tri-Z cooling problem...
Old May 3, 2004 | 02:30 PM
utahxjer's Avatar
Default Tri-Z cooling problem...
Ok, I just changed out my cylinder gasket. Then I filled up the radiator, but the coolant doesn't seem to be circulating through the system. What do I need to do?
thanks in advance,
-Rory
Old May 3, 2004 | 04:54 PM
deathman53's Avatar
rebuild the thermostat or take it off. alot of people took it off, however the bikes takes longer to warm up when you do so.
Old May 3, 2004 | 05:17 PM
86250Rs's Avatar
Not sure if this is your problem or not but if your getting no water circulation what so ever, its a good possibility. The tri-z 250's had a big problem with the water pump impellers, that would be the first place I would look.
Old May 3, 2004 | 11:25 PM
utahxjer's Avatar
the problem is it was circulating just fine before I just replaced the cylinder gasket two days ago and drained it all. Now I fill up the radiator and it just sits there???
IMLN
Sep 28, 2015 03:32 PM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
Polaris Side by Sides
Sep 15, 2015 03:33 AM
alzgarvin
Sep 11, 2015 08:53 AM
lancemll88
Sep 5, 2015 03:16 AM
