help trail blazer
Old May 4, 2004 | 06:31 PM
daatv's Avatar
Default help trail blazer
I have a 2001 trail blazer my sparke is good when i first crank it over but a few sec. it gets weak and weaker till there is nothing if i wait for 10 or 15 min. then i have good sparke again but does the same thing again it will not starte hopfuly someone has a clue of what is wrong replaced the sater,coil ,and the cdi still the same HELP
Old May 4, 2004 | 06:40 PM
Bradracer18's Avatar
Did you replace the plug....I assume you did....Check all of you connections, from battery on to the plug......
Old May 4, 2004 | 07:10 PM
daatv's Avatar
yes replaced the plug and check all con.
Old May 4, 2004 | 08:15 PM
simster570's Avatar
also make sure your using the right spark plug and the right gaps(if you replaced it) I can post the type of spark plug up here later when I go and work on my trailblazer. I do know that the gap should be .028 mm
Old May 4, 2004 | 08:36 PM
it should be a br8es.....I think, that is what is in my sport, and should be the same plugs....
Old May 4, 2004 | 08:41 PM
simster570's Avatar
Yes that is right.......... daatv, use and NGK type #br8es set at a .028 mm gap and see if that works...
If your already doing that, I dont know what to tell you
Old May 4, 2004 | 09:27 PM
daatv's Avatar
that is the plug that im using .I put a nother type of plug on the and laid it across the head as long as i held it on there tightly ihad little spark what would be the chances of being a bad stater ? I got off ebay it was new in the plastic.
Old May 4, 2004 | 10:24 PM
simster570's Avatar
If you have a spark then you should be alrite. If it is to little you may have a bad spark-plug-initer thing. Try giving the pull start a tug and see if that works. if it does, you probly have a bad starter.
Specta
Family ATVing Photos
Dec 7, 2018 08:22 PM
Alex Rodak
Sep 11, 2015 11:42 PM
craacker
Sep 9, 2015 04:32 AM
awer1968
Sep 8, 2015 11:02 AM
MikeyBoyesq
Sep 7, 2015 10:44 PM
