need a quik answer!! Recoil cover removal
Old May 5, 2004 | 06:37 PM
Redbullssg's Avatar
Default need a quik answer!! Recoil cover removal
I don't have a maint book, and am trying to get the recoil starter cover off. I have removed the chail and all the bolts, but the frame, or I should say gusset, is in the way on the bottom left corner, and I can't seem to work around it to get the damn thing off. WHat is the trick here? Do I have to pull the motor mount bolts just so I can clear it?
PLEASE HELP!!!!
Old May 5, 2004 | 06:41 PM
thewayout420's Avatar
im not sure on your machine but the cover cam right off on my scrammy..
Old May 5, 2004 | 06:43 PM
Redbullssg's Avatar
maybe I should add that mine is a 1997 scram 4x4.
Old May 5, 2004 | 06:58 PM
Redbullssg's Avatar
Ok, kinda figured out what is going on. I thought that it just wouldn't clear, but apparently there is something that fits inside the cover on the lower left side where that boss is, and it is sticking in the cover not letting me pull it up and out. What is that, and how can I get it to stay in the motor side and not the cover?
Old May 5, 2004 | 07:05 PM
is it your starter bolts?
Old May 5, 2004 | 07:12 PM
BeltDrive's Avatar
That is your starter gear that turns your flywheel. Try to pry the engine case up just a little to help clear the frame. I did that with my 02 400 4x4 scrambler. If it's about the same
Old May 5, 2004 | 07:14 PM
Redbullssg's Avatar
na, it was a small gear that actuates the flywheel. I got it, and again I feel stupid. lol!!! I am in a crunch for time. THanks for the help!!!
Old May 5, 2004 | 07:16 PM
Redbullssg's Avatar
Oh thank you too beltdrive. I didn't see your post before I replied.
Old May 5, 2004 | 07:18 PM
BeltDrive's Avatar
If it is coming out with the cover and if you can get your cover off far enough to get a long screwdriver in there to push the gear drive back in. You should be able to get the cover off. I don't know if you can get the cover off with the gear drive as one unit.
WesTech
11
Aug 11, 2015 07:55 AM
Captjay
Jul 23, 2015 12:33 PM
Desimation2k8
Jul 17, 2015 12:37 AM
ghost civic
Jul 15, 2015 10:48 PM
cSchwartz
Jul 9, 2015 02:43 PM
