Banshee Back Fires, and loads up really slow, PLEASE HELP
Old May 6, 2004 | 02:15 AM
Eclipsegsx's Avatar
Default Banshee Back Fires, and loads up really slow, PLEASE HELP
I have only had my 99 banshee for about 2 weeks and barely ran a half a tank of gas through it, and all of a sudden it started to back fire, and now it is doing it quite often. And when i start out it is seems really sluggish, and then when i go to get on it, it seems like it doesnt want to go at all until you give it all the gas that it has and hit the power band.
I mean it was working fine for a while and then it started doing this, please help anyone at all. I have no idea what is wrong and i havent had time to call the yamaha shop. P.S. for the half of tank of gas that i have ran it, i ran a gas mixutre of 40:1.
Thank you for your help Eric
Old May 6, 2004 | 02:19 AM
Devin246's Avatar
you could try different oil or runnin 32:1 or both.
Old May 6, 2004 | 10:05 AM
Hiram's Avatar
Make sure the carbs are really clean, as it seems to be running lean from clogged jets or from too small a size.
Old May 6, 2004 | 10:09 AM
Shav0's Avatar
When is it backfiring? If it is backfiring from after you let off the gas from 3/4 - full throttle then it usually means your pilot circut is lean. Try turning in your air screw. If that dosn't work then you will need to go bigger on the pilot.
Old May 6, 2004 | 10:56 AM
Eclipsegsx's Avatar
Ok, what exactly should i do to clean my carbs, is there somthing i put in my gas, or should i have the dealership clean them. THANK YOU FOR ALL OF YOUR HELP SO FAR.
Old May 6, 2004 | 11:52 AM
Shav0's Avatar
Are you good with that kind of stuff? Its real easy to do. All you need to do is remove the carbs, take off the tops, remove and clean the springs, needles, and then remove the bowl and you will see two jets, a pilot and a main, remove and clean both of these and the holes they are in.
Old May 6, 2004 | 11:53 AM
Shav0's Avatar
If you have only had a tank of gas in her then you probably don't need to clean them yet. I would suggest going up on the pilot jet or turning in the mix screw.
Old May 6, 2004 | 03:45 PM
bansheeridr's Avatar
Hey, some times it is the eaisest things. Check you spark plugs, that might be the problem, i know you prolly already did but it was just a suggestion.
Old May 6, 2004 | 05:30 PM
gomer73's Avatar
if it is your carbs this site has a step by step break down of the carbs http://www.thebansheezone.com/Bansheezone/AirIntake.htm
and this site tells you about jetting
http://www.bansheehq.com/modules.php...gories=Jetting
i hope this helps you out there is another but i cant find it now
Old May 7, 2004 | 12:08 AM
Eclipsegsx's Avatar
thankyou for all your help i will let you know what happens after i break the carbs down.
hugemoth
Jul 20, 2020 03:28 AM
bzdok1234
30
Feb 23, 2016 01:55 PM
Sjrpp
Jul 5, 2015 09:04 PM
J-Mack
Polaris Side by Sides
Jul 4, 2015 04:19 PM
bzdok1234
Utility ATVs
Jul 3, 2015 05:32 PM
