Pred. 90 Rear Hubs - 03
Old May 6, 2004 | 03:11 AM
Pistonman's Avatar
Default Pred. 90 Rear Hubs - 03
Have my daughter's P-90 apart for FMF pipe install and tranny fluid change and noticed the rear hubs are loose. I can wiggle the nut, cotter pin is intact, axle sleeve also loose(held tight by hubs) You might want to check yours.....
Old May 6, 2004 | 07:06 PM
csamayfield55's Avatar
Have tightened my sons twice now and they need it again!! Make sure you greese those splines when you tighten them back up
Chris
Old May 7, 2004 | 12:15 AM
Pistonman's Avatar
Thanks for the tip... So instead of just tightening the nut, I should take off the hub and grease the splines. What about using anti-sieze?
Old May 7, 2004 | 02:42 AM
biscuit's Avatar
Wait till you forget to put the cotter pin back in and have the wheel come off, I use an impact wrench now, it goes nowhere.
LOCKTIGHT EVERY BOLT YOU CAN! I've had'em all come loose.
Old May 7, 2004 | 07:11 PM
never used antiseaze on those, just synthetic grease like everywhere else
Chris
blueandy88
Sep 7, 2020 03:11 PM
twon1235
Utility ATVs
Sep 7, 2015 04:38 AM
snowolson
Aug 31, 2015 03:51 PM
blueandy88
Aug 31, 2015 12:42 PM
blueandy88
Aug 30, 2015 08:26 PM
