front differtial lock doesnt alway engage both wheeels
Old May 6, 2004 | 10:01 AM
Xrxman's Avatar
Default front differtial lock doesnt alway engage both wheeels
sometimes on my 02 650 prairie, when i pull the yellow handle both front wheel dont turn is there an adjustment for this??
Old May 6, 2004 | 10:13 AM
EasterEgg's Avatar
Yes there is an adjustment. Go to nyroc's tech site for instructions. Found out this weekend mine was the same way. HTH
Old May 6, 2004 | 10:18 AM
Xrxman's Avatar
Thanks for the help
Old May 6, 2004 | 10:57 AM
KINGSCLEAR's Avatar
Buddy of mine just shreaded is front end because of this same problem he has the new 700. They do not even have parts available yet. Only one side locked in the other was in between
Old May 6, 2004 | 11:01 AM
Xrxman's Avatar
Are referring to John M in Brookdale if so he one of my neighbors, I see you are from kinsclear
Old May 6, 2004 | 11:10 AM
KINGSCLEAR's Avatar
not sure of the guys name he is a friend of a friend
Old May 6, 2004 | 12:06 PM
700vtwinman's Avatar
Mine did that, but my dealer fixed it. He also said I could do it any time it does it by adjusting the connection at the front differential. He also said that once you adjust it, that it should not need any more adjusting since the way it comes from the factory is loose sometimes.
Old May 6, 2004 | 03:03 PM
bbertram's Avatar
IF you run big heavy tires you will need to adjust it too.
Old May 6, 2004 | 04:24 PM
Kartmann's Avatar
stupid questions, how do you adjust it?
mudmagnet's Avatar
Make sure your oil level in the front diff is full. If not it will not lock.
