Carb jet size for ported 400L motor
Old May 6, 2004 | 10:21 AM
luvit's Avatar
Default Carb jet size for ported 400L motor
Finally!!! I am going to put this motor back together this weekend. Rebuilt the top end of my 99' Sport 400. Also, I bought a sport port kit from race logic and had my friend do all the machine port work for me. Therefore, I would think I would need to rejet the carb? What size do you think? Or will I be ok w/the stock since I have not done the aftermarket pipe and clutch kit yet, that is next.
Old May 6, 2004 | 01:19 PM
Bubba297's Avatar
Watch out for detonation with the stock pipe until you are able to get another one. As a rule of thumb, I always either move the clip down a notch on the needle or go up one size on the jetting. Most of the time you'll end up where you started, but get it broke in first. Bubba
Old May 6, 2004 | 05:59 PM
scramblered's Avatar
with the stock 34 mm carb,stock pipe (that sux) start at least at
240-250 main jet,needle raised one notch (drop the clip)your next step then is reeds.
Old May 7, 2004 | 08:40 AM
luvit's Avatar
I am replacing the reeds with Boyesen dual pedal, low thru mid range power.
Hankey Pankey
26
Oct 18, 2020 03:50 PM
bzdok1234
30
Feb 23, 2016 01:55 PM
tweeder
Jul 5, 2015 01:57 PM
bzdok1234
Utility ATVs
Jul 3, 2015 05:32 PM
bikedad3
Jul 2, 2015 02:15 AM
