rejetting YFZ.....PLEASE HELP ASAP!!
Im trying to figure out how to change the needle notch on the YFZ carb. I have no idea what im doing and what to look for. I changed the jet but i cant find out how the change the needle. HELP!!!
Remove the top off of the carb. You will see a allen head set screw when you look in. Remove that and the needle is under there. Move the C clip to what position you want.
Runs like-
Flat part
1-lean
7-rich
taper
Runs like-
Flat part
1-lean
7-rich
taper
Did you pull out the carb or are you just twisting it while its connected to the bike? To reach the top of the carb you must reach it through the right side of the bike. Like the guy above me said take the top of the carb off and remove it from the hex.
slowgsxr97
Sep 8, 2015 07:33 PM
400H0
10
Aug 20, 2015 07:34 PM
