jetting
Old May 7, 2004 | 11:15 PM
yamaracer's Avatar
Default jetting
i just had a hmf slip on installed on my yfz450 and was wondering if its normal if it backfires when i let of the gas. it doesnt do it real bad unless i get on it hard then let off quickly. is it because my jettings wrong cause i read somewhere that if it backfires it means its running lean or is it just because of the pipe. any help would be appreciated thanks.
Old May 8, 2004 | 12:24 AM
ShockMe's Avatar
Default jetting
Did you rejet after the slip-on?
Old May 8, 2004 | 02:25 AM
yamaracer's Avatar
Default jetting
yea i had my dealer install it and rejet it
Old May 8, 2004 | 02:30 AM
ShockMe's Avatar
Default jetting
It sounds like you are a little lean. let the dealer fix it. Do you know what size jet and pilot they put in.
Old May 8, 2004 | 03:06 PM
hondarider300's Avatar
Default jetting
my quad does that too somtimes when i let off the gas at high speeds/rpm's, most people tell me this is normal its not real bad backfiring just a little popping. it shouldn't be a big deal. and im pretty sure mine is jetted perfectly
Old May 8, 2004 | 03:17 PM
ShockMe's Avatar
Default jetting
If it was jetted perfectly it wouldnt pop on decel. you might try opening the fuel screw a 1/4 turn or so to fine tune it. If you can live with the popping your probably ok.
Old May 8, 2004 | 05:18 PM
dragracer789's Avatar
Default jetting
My friend has a GYTR pipe on his and it backfires alot. We messed around with the jets alot and air screw. nothing happend, so we think its just the back pressure issue.
Old May 8, 2004 | 06:26 PM
ringer's Avatar
Default jetting
Check all bolts on header and clamps.If there loose and air is getting in it will make it pop on deceleration.Also check carb boots.
ReconBayou
Oct 31, 2022 05:37 PM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
XxS0ccerstarxX
Sep 8, 2015 12:02 AM
