Low end bog
Old May 9, 2004 | 02:08 AM
Entomber's Avatar
Default Low end bog
I was riding my Raptor and seems to bog a bit on the low end. If I scream it it's fine.
Changed the plug and wicked the choke to see if it's stuck. It's neither. What adjustment in the daunting carbs should I do?
Also what should the turns be on the air/fuel mixture screws on the bottom of the carb? I forget what it's supposed to be set at.
Old May 9, 2004 | 02:05 PM
Devin246's Avatar
Default Low end bog
I have a banshee and i think im having the same problem, also looking from the back my right pipe is smoking quite a bit more than the left. Its brand new so i dont think it should be a problem with the motor. Ent it says what your stock jetting should be at in your manual.
Old May 9, 2004 | 03:15 PM
RoostItUp's Avatar
Default Low end bog
When the bike bogs it usually means a lean fuel mixture whereever the bog is at. first try richening the air/fuel screw if that doesn't work put a bigger pilot jet in. What have you done to the rappy to need more fuel?
