plug fouls
Old May 9, 2004 | 09:14 AM
januaryman's Avatar
Default plug fouls
i got such a good response on my last post i thought i might trym again! i took the scrambler 400 riding again yesterday and all was well,until the end of the day.i shut it off to get ready to load up but it wouldnt start back.changed plugs and it fired right up.it has done this to me 3 times .but i have no problems when riding it.any ideas on what might be happening! all replies are appreciated!
Old May 9, 2004 | 09:18 AM
thewayout420's Avatar
Default plug fouls
you could be running rich?do you open the machine up?sometimes riding slow will make the plug buildup and foul it out..
Old May 9, 2004 | 09:24 AM
januaryman's Avatar
Default plug fouls
yesterday i did lug it around quite a bit.we had some very slow riders with us.i also noticed it was smoking quite a bit.
Old May 9, 2004 | 09:28 AM
januaryman's Avatar
Default plug fouls
i believe the stock plug number is a d7es. but it runs better with a d8es.is the 8 hotter or cooler?
Old May 9, 2004 | 09:31 AM
quadwrench's Avatar
Default plug fouls
You need to check your counterbalance oil level, sometimes the excessive smoke is caused by the crankshaft seal in the balance shaft sump leaking oil (or allowing it to be sucked) into the crankcase. This will also cause fouling of the spark plug.
Hankey Pankey
May 1, 2018 01:33 PM
Shainasmash
May 8, 2017 06:38 PM
Hankey Pankey
Aug 17, 2015 05:01 PM
cornermike
Jul 30, 2015 06:37 AM
Captjay
Jul 23, 2015 12:33 PM
