predator compression testing procedure
Old May 9, 2004 | 11:27 AM
got2gofast's Avatar
Default predator compression testing procedure
I was just wondering if testing the compression on a predator is the same as on a snowmobile, or if 4 -strokes are different? Just clamp the throttle open and ground the plug wire and turn in over? SHould the engine be warm or cold? thanks
Old May 9, 2004 | 03:20 PM
modquad's Avatar
85-90 psi @ est 400 rpm cranking speed. A low pressure leakdown test is the best method. Don't use a high pressure leakdown, due to the risk of blowing out crank seals.
slowgsxr97
Mar 18, 2022 03:40 AM
fordfaithful21
Dec 7, 2015 05:52 PM
Hankey Pankey
Jul 31, 2015 05:50 PM
Hankey Pankey
Technical and How-To Articles
Jul 29, 2015 10:57 PM
southbayman
Jul 24, 2015 09:30 AM
