Quick question about rejetting the scrammy.
Old May 9, 2004 | 01:06 PM
ScRaMbLeRiZeD's Avatar
Default Quick question about rejetting the scrammy.
I was wondering if i should rejet my scrambler if I was to just change the stock silencer with the fmf turbine core2. I am also running a K&N air filter. I didn't rejet after putting in the filter either so would i be losing any power without rejetting after the replacement. Thanks.
Old May 9, 2004 | 01:34 PM
CED's Avatar
CED
The best way to tell if you need to rejet is to look at the plug.Do a couple runs at 1/4,1/2 and full throttle and see what the plug looks like at each position.
Old May 9, 2004 | 04:41 PM
DGScrambler400's Avatar
Do as CED said, you may have to rejet.
P.S. Do you have any picture of your Scrammy?
Old May 10, 2004 | 02:55 PM
thanks for the replies I'll be sure to check the plug once I get it installed. I'll try to get some pics posted in a day or two.
Old May 10, 2004 | 09:56 PM
Redbullssg's Avatar
Quick question, and may sound dumb, but isn't a 260 main fatter than a 250. Looking at the two side by side, it looked as though the 260 was smaller. When ridding the dunes, do you want to be richer?
Old May 13, 2004 | 12:58 AM
700quadman's Avatar
Redbull-
A 260 is larger than a 250. When riding the dunes, you want to be jetted properly, not too rich, not too lean. However, for sustained WOT operation anywhere, a little bit rich is better than a bit lean; won't overheat as soon.
Old May 13, 2004 | 01:21 AM
Redbullssg's Avatar
Well, I figured out that the 260 was just varnished a bit, thanks.
Old May 13, 2004 | 01:45 PM
scramblered's Avatar
stock scrammy with stock jetting just a k&n,you should be fine,but that fmf is less restrictive than the stock unit for sure,i would go for a
fuel screw riching,than maybe little richer main jet and needle.
cornermike
Sep 10, 2015 08:30 AM
Albertaboyy
Sep 9, 2015 09:51 AM
MikeyBoyesq
Sep 7, 2015 10:44 PM
black_thunder
Sep 6, 2015 04:41 PM
Logan Collins
Sep 5, 2015 08:03 PM
