Where do I mount a Trail Tech speedo on my Scram?
Old May 9, 2004 | 04:52 PM
DGScrambler400's Avatar
Default Where do I mount a Trail Tech speedo on my Scram?
The topic explains it[img]i/expressions/face-icon-small-wink.gif[/img] Where do I mount the Trail Tech? ...also, which one do i order, is it the one for Polaris 4x4s?....[img]i/expressions/face-icon-small-smile.gif[/img]
Old May 9, 2004 | 06:11 PM
BigBadScrambler's Avatar
Yep, the one for the Polaris 4x4's. Check my pics for where I mounted mine. Its mounted to the headlight bracket for easy visability
Old May 9, 2004 | 07:03 PM
thanks BBS. It looks like i can just play around with it and see where i like it best. How long did it take to hook up, does it come with easy instuctions?
Old May 9, 2004 | 07:09 PM
tbsleeper's Avatar
the one hard part is drilling a whole for the magnet thing to go in. and u gotta remove a bolt and replace it so not to hard.
Old May 9, 2004 | 07:12 PM
what will i need to drill a hole in?...i am asking too many questions..[img]i/expressions/face-icon-small-smile.gif[/img]
Old May 9, 2004 | 07:18 PM
tbsleeper's Avatar
u have to remove one of the brake rotor bolts and replace it with a magnet and u have to drill a whole in the ummm ummmm....
Old May 9, 2004 | 08:25 PM
You drill a hole in the strut housing to mount the sensor. Very easy. For the 4wd models, you attach a magnet to the brake rotor. JB Weld works good for that. Then just run the wiring. Should take less than 1/2 hour. The hardest time I had was getting the magnet and sensor aligned properly. Overall it was a very easy install. Do you have the stock size tires on the front? If so, I have the number that needs to be programed into the Trailtech for the tires. NCScrambler gave it to me and had it GPS verified
Old May 9, 2004 | 09:34 PM
thanks for all of the help everyone BBS, i sent you a PM...
Ramman1
Aug 11, 2022 01:53 PM
readymixer169
Aug 21, 2015 10:05 AM
MNatv89
Aug 10, 2015 02:20 PM
maxjung
Jul 23, 2015 08:37 PM
Nondem
Where to Ride
Jul 23, 2015 07:38 PM
