Bend my Raptor tie rod, help!
Old May 10, 2004 | 12:02 AM
artoux's Avatar
Default Bend my Raptor tie rod, help!
Went out riding today and bent my tie rod on a rock. I have +2,+1 " a arms. I started to take the cotter pin out and unscrew the nut and then I got stuck. How do you get that tie rod out? Also how do you put it back in?
Thanks You for your input, it is greatly appreciated. I need to RIDE!!!!
2001 Alba Raptor
+2"+1" a arms
+3" Excalibur axle
+2" Alba Swingarm
Steel braided lines
Dg nerfs
Maxxis Razr's on Douglas aluminums
Pep Steering Stabilizer
Elka Tripe Rate Shocks with remote resevoirs
rear shock revalved
Chuck-Raptorman
No. Calilf.
[img]i/expressions/face-icon-small-sad.gif[/img]
Old May 10, 2004 | 06:14 PM
blue250r's Avatar
You should be able to get your tie rod to screw out of the ball joints by turning it in the direction that lengthens as if you were adjusting your steering track it if you see what i mean unless its bent real bad
then you will have to pop the ball joints out, Im not sure about the raptor but most bikes U just remove the split pin remove the nut then get the hub where u can get a good solid hit at it and hit the part of the hub that the ball joint pin goes through the shock should make it jump out as it is a tapered shaft.
Somtimes trying to prize it out at the same time will help. DONT go beating up the thread part where u took the nut off as this rearly works and just mushrooms the end.
If That doesnt do in u might need to buy a ball joint spliting tool
good luck
Old May 11, 2004 | 12:20 AM
artoux's Avatar
Blue,
You have good advise. I took out my tie rods by unscrewing them with the tire off. I then found out that the part damaged is the ball joint. I tried to get the ball joint out by releasing the cotter pin and unscrewing the nut a little. Then with a couple of taps with a hammer and a 2x4 it still didn't come out. Not damaging the threads either. I think I now need a ball joint splitting tool.
Tanks Chuck-Raptorman
Old May 11, 2004 | 12:41 PM
Mike330R's Avatar
I'd suggest getting the Ricky Stator yamaha tie-rod kit. It converts it to Honda style and is much stronger especially for the wider stance.
www.rickystator.com
Old May 14, 2004 | 01:18 AM
artoux's Avatar
To all,
Thanks for your help. Got my tie rod in tonite. Went out to the garage, tapped the tie rod end out of the a arm .Installed the new one ,screwed it into the tie rod, adjusted the camber.
It took a whole 15 minutes, Thanks much for your help.
Raptor is ready to Rumble again!!!!! [img]i/expressions/face-icon-small-cool.gif[/img]
bmxatv10
Oct 14, 2022 06:23 PM
black_thunder
Sep 22, 2015 07:59 PM
Alex Rodak
Sep 13, 2015 12:30 AM
Alex Rodak
Sep 12, 2015 09:39 AM
Alex Rodak
Sep 11, 2015 11:42 PM
