holes in top airbx lid?
Old May 10, 2004 | 09:05 PM
quadblazer400's Avatar
Default holes in top airbx lid?
i have a 2001 scram 500, with hot seat speed kit in it, very satisfied with results, but i been told to drill holes in top of airbox lid for even more power, is that true? if so does carb need readjusted after holes are put in? also, how many , and how big should i drill holes? any input on this is appreciated, thanks
Old May 10, 2004 | 09:11 PM
waynaferd's Avatar
Your best bet would be to get some 1" airbox vents. I think they come in a 6-pack, and have foam in them to let in more air but they keep out the dirt and stuff. denniskirk or rockymtnatv should have them. You'll probably hafta rejet for sure....
Old May 10, 2004 | 09:17 PM
thanks for input, do you know how much of a gain it would be? is it worth it? also bigger jets were installed with speed kit, would they need changed?
RAJ's Avatar
RAJ
3 one inch holes will do ya fine. After you do this make sure you re-jet.
Old May 10, 2004 | 09:46 PM
proXpilot's Avatar
D&D makes filters called bullzye's i run them in my sled air box the come in a 6 pack and they even come with caps so you can close them off if you want. http://www.ddracing.com
Old May 10, 2004 | 11:34 PM
quadracer18's Avatar
Ya,,,its simple..if you put holes in it..your going to get more airflow which is always better..and of course you'll have to rejet to even out with the extra air...have you thought about that new k&n power filter that takes place of the airbox lid??? I heard those things are pretty sweet.
Old May 10, 2004 | 11:42 PM
thewayout420's Avatar
i heard that the 500 needs to have the airbox to run right,i dont know if there is any truth to it?
franklyme
Oct 21, 2016 07:18 PM
Sassinm1
Sep 30, 2015 04:23 AM
2many2ride
Sep 27, 2015 04:35 AM
MikeyBoyesq
Sep 22, 2015 10:02 AM
toonces
Sep 5, 2015 01:14 PM
