OVER HEATED
Old May 11, 2004 | 03:55 PM
hawleywood's Avatar
Default OVER HEATED
Last night I was riding going up a long step hill when I top it started to desend the motor quit look at my overflow and the engine ice was sprying out on my legg but it was not hot enough to burn my legg. when i turned the key over the fan ran for only a couple of minutes and on top of the head it looks like there is gas and oil coming out of one of the head bolts.
this motor just received a top end rebuild with a wiseco piston and the head milled .015 m going to tear it down tomorrow what should I check for.and should I be using some kind of sealer around the head studs?check the plug also and it was brown so it wasn't lean
Old May 11, 2004 | 05:17 PM
scramblered's Avatar
Default OVER HEATED
be sure to torque spec the head bolt after a run when you got a rebuild,
it just look an un-sealed coolant system problem to me,bleed the coolant
system properly,you can even put loctite or high performance silicone on them before screw them in.
Old May 11, 2004 | 06:08 PM
hawleywood's Avatar
Default OVER HEATED
what is the proper way to bleed the head and since I got it pretty quick do you think it did any damage!!
what adapter do you use for the torque wrench to do base nuts and were can I get one
thanks
Scott
Old May 11, 2004 | 09:49 PM
modquad's Avatar
Default OVER HEATED
Like Scramblered stated, it's pretty important to re-torque those base bolts. Many of us who have been through the top-ends on a regular basis (not due to failures, just freshening every once in a while due to 15.5:1 race mods)don't use a torque wrench on the base bolts, we use the "calibrated" method of estimating. If you want, you can use the torque wrench on the couple of bolts which are easy to get to, then estimate on the others.
There is a air bleed screw on the RH (viewed as your sitting on it)side of the head. By the temp sender. Also, Redline's Water Wetter helps cooling a bit more, and also seems to have greater lubricity.
Old May 11, 2004 | 10:59 PM
Whitedog's Avatar
Default OVER HEATED
Id also check the 6 studs in the top of the jug. You may have a couple loose. if they werent loose then, they may be now. (since it got hot) I dont think I like the gasket stuff some people use, the gasket allready has some kinda sealer on it. Also wont hurt to drop the head off at a machine shop to check to see if its warped. My cousin ran his hot this winter, and it took 3 tries till we finally gotit rite.
Old May 11, 2004 | 11:07 PM
csamayfield55's Avatar
Default OVER HEATED
Do the 2 strokes have thewrmostats?? Sounds like the stat failed closed so no water was getting through to the cooler.
Chris
Old May 12, 2004 | 12:02 AM
Polaris500HO4x4's Avatar
Default OVER HEATED
csamayfield55
how do you like the exhaust on your 500 HO. can u tell any difference on power i was looking at one also. did u rejet it
Old May 12, 2004 | 10:20 AM
hawleywood's Avatar
Default OVER HEATED
what procedure do you use to bleed the head .....crack the bleeder while it is running until fluid comes out????[img]i/expressions/face-icon-small-confused.gif[/img]
Old May 12, 2004 | 11:19 AM
modquad's Avatar
Default OVER HEATED
The 2- stroke 400 engine doesn't have a thermostat. You can back off the bleeder screw, then pour in coolant. You'll eventually see some coolant leak out.
As for adding additional sealer....like Whitedog stated, there's already a bead of silicon on the gasket. It's just very important to re-torque once the machine has been thoroughly warmed. Considering we triple the horsepower from these motors (reliably), they're a very durable design. [img]i/expressions/face-icon-small-smile.gif[/img]
Old May 12, 2004 | 11:31 AM
badazz400's Avatar
Default OVER HEATED
wouldnt b a bad idea to invest in a water temp guage. i got one and i love it. like white dog said, check head for warps. i took my head off and had it shaved when mine overheated, but i still had a antifreeze leaking. turned out to be the top of my jug was warped. for 25$ you can have it milled. id defintly have my jug checked out too.
ross
Jeff Roper
Feb 1, 2022 11:48 AM
Sw00p
Sep 24, 2015 02:50 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
Jeff Roper
Sep 21, 2015 02:11 PM
poutlaw525
Sep 9, 2015 03:19 AM
