oil leaking from crank bolt inside starter
Old May 11, 2004 | 05:18 PM
madtyper's Avatar
Default oil leaking from crank bolt inside starter
gday all, i have a 2001 praire 400 4x4. the recoil starter would not wind up so removed it found that the gasket was gone. in the process of putting back together noticed that there was oil seeping from the crank bolt. it needs a new seal in it. one problem, every time that i try to take the bolt out the engine turns over. how do i stop the motor from turning. i have herd to put a piece of rope in the spark plug hole and this will jam the pistion up, sounds a little risky, anyone have any other ideas?
thanks
madtyper
praire 400
giddy up
Old May 11, 2004 | 07:49 PM
nyroc's Avatar
Use an impact wrench to get it off. Go buy a torque stick when you put it back, or buy kawasaki's engine holder tool. I would stay away from the rope in piston trick. I am sure it will work, but if one of the valves is open, that could be a very bad trick.
ghost civic
Jan 15, 2020 07:43 AM
Desimation2k8
Jul 17, 2015 12:37 AM
ghost civic
Jul 15, 2015 10:48 PM
Countrygirl1976
Jul 13, 2015 10:08 AM
Unzzy66
Jul 11, 2015 10:01 PM
