Rubber between tank and valve cover/carbs on Rappy
There is rubber between the gas tank and valve cover and also between the carbs and the tank. Are these necessary? What purposes do they serve besides water drainage and a buffer between the carbs? I ask because I accidently forgot to put the front one on that goes around the steering stem and didn't know if I needed to put it back on er not. Thanks guys.
Ive ran mine for a very long time without them on. The motor gets a lot dustier, as do the carbs..just be sure and clean it off before tearing into something to work on it. I havent had one issue with taking them off..no big deal.
