Bounce's off rev limiter in 5th.
Is this normal? I have a trail tech speedo and i do 73 mph (top speed) in 5th and at that speed I am bouncing off the rev limiter, lots of power still there.
All stock 04 DS 650 Baja X.
That sounds about right. You can do 1 of 2 things. The cheaper being to go up 1 tooth on your countershaft sprocket. The slightly more expensive being to change out your CDI for one with a higher rev limit. There are several good ones out there depending on how much you want to spend. The DS is notorious for hitting the stock rev limit. Good luck.
Steeldon
Sep 9, 2015 09:38 AM
