Having probs taking the inside wheel bearings out of......
Old May 12, 2004 | 05:39 PM
scroder's Avatar
Default Havind probs with taking the inside wheel bearings out of......
The rear carrier. One of my bolts broke inside the wheel bearing carrier and wouldnt come out with an extractor. I bought the new carrier ($105 at Polaris) but is a bare setup with no bushings or bearings. So how do i get them out of the old one and into the new one. I took the lock ring off but cant get anything else out---anyone else ever have to do this?---thanks----Dave
My bad--its a 2001 Sportsman 500 HO
Old May 12, 2004 | 05:46 PM
thewayout420's Avatar
Default Having probs taking the inside wheel bearings out of......
what machine do you have?and what bolts broke?i dont recall any bolts inside the carrier on my scrambler..
Old May 12, 2004 | 08:01 PM
tbsleeper's Avatar
u need to buy a manual because u have to remove the whole rear axle to do wat u want. i j ust did it to mine last weekend and u have to slide it out the right side by removing the chain sprocket..so on so on
Old May 12, 2004 | 09:22 PM
scroder's Avatar
I already have the bearing carrier out----that was the easy part---So i went and bought the bearings to put into the carrier and even after hitting them with a rubber mallet I cant the damn things in
Old May 12, 2004 | 09:26 PM
tbsleeper's Avatar
well u have to kinda work them on, u just dont hit them, what we usud was kind like a pic or somethinglike a flathead screwdriver and easily banged the bearings over the hard areas.
Old May 13, 2004 | 09:01 AM
quadwrench's Avatar
This is the rear axle carrier for the SP500. After you remove the snap ring, a large hammer and large punch (a 1/2" drive ratchet extention will work if you don't mind messing it up) will drive the bearing out in the direction that the snap ring came out.
Before putting everything back together, make sure the inner bearing race is not still on the end of the CV axle (common problem, and it won't go back together like that [img]i/expressions/face-icon-small-wink.gif[/img])
Old May 14, 2004 | 02:35 AM
scroder's Avatar
thanks for the help wrench---Dave
toonces
Oct 16, 2019 12:11 PM
coolguy420
Jul 10, 2015 01:17 AM
yambam13
Jul 4, 2015 01:49 PM
D-Hagz
Jul 4, 2015 02:19 AM
Shifts
Jul 3, 2015 07:59 AM
