Stripped Shifter Fix
Old May 14, 2004 | 06:07 PM
warmdye's Avatar
Default Stripped Shifter Fix
I have an 87 Tecate 4 with a striped shifter. The shifter shaft has some splines left but is somewhat egg shaped. I really don't want to have to split the case to fix this. Anybody have a good fix for a striped shifter. I have seen people drill a hole through the shifter and the shaft and put a bolt through it but I know one guy that had his shifter shaft break complete after doing this. I was thinking about making a slot in the shaft and the shifter and using some sort of key, but this seems difficult. Welding it on is not an option. Any Ideas?
Old May 14, 2004 | 07:53 PM
92LT's Avatar
Click here
A lot of times it really isn't hard to replace the shift shaft. A lot of times all that is neccessary to do is remove the right side case and possibly the clutch basket. I suggest replacing the shift shaft and shifter. I've never done it on a tecate motor, but I'm sure someone on this board has done it and can tell you what is involved in the tecate motor. Good luck.
Old May 14, 2004 | 08:25 PM
warmdye's Avatar
I would like to replace the shaft but the previous owner had welded the kickstater to the kickstarter shaft so I can't remove the right side cover unless I buy a new kickstarter shaft and kickstarter. Lots of cash for such an old bike.
thats good info in that tech tip. after reading that and relooking at my shaft I think I will try a new shifter. The c clamp I was definelty not tightinng all the way.
Njrider1230
Jul 29, 2023 05:16 AM
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
tysonbully
Sep 28, 2015 02:30 AM
Steeldon
Sep 9, 2015 09:38 AM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
