Change pilot jets or not???
Old May 14, 2004 | 07:04 PM
bluethunder's Avatar
Default Change pilot jets or not???
I just installed a full yoshi system on my raptor,going from a slip on GYTR pipe. I jetted it at 148,150 dynojets. Ive always run with no lid,even with the GYTR pipe. I have the stock pilots with 3 turns out on the air screws and im at sea level. Anyways, my buddy is insisting i change the pilots too bigger ones,he swears i will get more response and low end power by doing this. It seems too run good now,responsive and everything. I tell him if you can tune it with the air screw ,then you dont need bigger pilots.Am i wrong or is he correct?? Anybody do this from experience?? I would just try it too shut him up(lol) if it wasnt such a pain in the *** too jet this thing,any good input appreciated
Old May 14, 2004 | 08:18 PM
Outlawlawndragster's Avatar
Your spark plug will tell the story . What's it look like .
Looks like your running stock bore and compression . I probly wouldnt touch it. if you increase bore and comp then you might . Hard to say Sounds like youve got lot's of oxygen seeing how your at Sea level . so watch your plug color .
Old May 14, 2004 | 08:59 PM
1BADRAPTOR's Avatar
with that set up i would switch to 25 pilots, that is what i had mine at and it ran real good, you have almost the same set up as i did before..
Old May 14, 2004 | 09:19 PM
rc3's Avatar
rc3
I know where I live i have the same set up as you and I am at sea level and I had to go to 27.5 pilots, well I hope that I have helped in some way
Bonzhonda300ex
Sep 17, 2015 10:44 AM
Brandon400
Sep 7, 2015 12:20 PM
Brandon400
Sep 5, 2015 08:44 PM
DanP24
1) Engine problems..
Aug 12, 2015 11:39 AM
Aitch
Jul 21, 2015 09:40 PM
