fuel injector faults
Old May 14, 2004 | 10:40 PM
hakeem's Avatar
Default fuel injector faults
I just got the D&M kit for cannibal and found that I have a "Injector A open fault", any suggestions?
Old May 15, 2004 | 03:16 PM
armoks's Avatar
Check it again if its clear your good if not make sure the connections are clicked in the whole way. If that don't work get a voltmeter and check the voltage in them using the manuals located here http://www.cannondaleriders.com/tech/index.shtml. if that doesnt work check down inside the connectors to make sure the little tabs arn't bent. hope this helps!
Old May 16, 2004 | 04:27 AM
WISTECH's Avatar
If it runs fine and the fault is not consistant it might just be a glitch . I had mine do that once. If it is consistant then check the connectors for damaged , bent pins or corrosion. Quite a few have gotten this code after an engine install. Those little connectors have to be treated with respect. Do not force them on.
ltrmc02
Aug 22, 2021 02:34 PM
Customer Service #1
May 15, 2020 08:46 AM
PrairieDog126
Sep 12, 2015 06:53 PM
craacker
Sep 9, 2015 04:32 AM
Elkaholic
Sep 6, 2015 02:44 PM
