Lights on 1985 ATC 250R
Old May 15, 2004 | 02:37 AM
toocko's Avatar
Default Lights on 1985 ATC 250R
My front and tail lights on my bike don't work. (1985 ATC 250R) Doing a search on this topic I read on one of the threads of someone talking about a fuse. Is there a fuse on this bike? If so where? Last I remember there were working. Is there a way to test the light bulbs with out buying new ones. Reason I don't want to buy new ones is like I mentioned, they were both working and for both bulbs to go out would be a big coincidence. Any suggestions would be appreciated.
Old May 15, 2004 | 12:13 PM
Lomax's Avatar
The bulbs are not likley the problem. I dont know where it is located on that machine ( if i get mine today then i will start looking for it so i can help a little more ) but that sounds like the culprit. If it is not, start chasing wires and check your switch its very possible that could be whats wrong.
Old May 15, 2004 | 11:03 PM
toocko's Avatar
It would be great if you can help. I'll try looking at the wires
Old May 15, 2004 | 11:32 PM
KASEY's Avatar
if you had a ohm meter you could check the bulbs to make sure that you didn't blow a regularor ,,, which in turn would have blown both of your bulbs,,, there is no fuse either,,,
Old May 16, 2004 | 09:07 PM
ATC250Rrider's Avatar
Kasey is right. There isn't a fuse on the R. It's easy enough to check the bulbs for starters. You can disonnect the headlight and remove the bulb easily. When you do this, MAKE SUE YOU DON'T TOUCH THE GLASS PART OF THE BULB. You can look at it and you should see two "springlike" filaments inside the bulb. If they're not there, then the bulb is blown. If they are then you eliminated on possibility.
More likely than not, your connections are dirty in your wiring system. What I would do first is take off your "On/Off" switch and make sure it's clean inside. Then I would take off the gas tank and look for the wiring harness connections between the radiators. I would check to make sure they are clean, then I would clean the ground wire connection that connects to your voltage regulator (it's mounted on the tail section of your bike and looks like it has cooling fins on it). More likely than not, it's dirty/corroded connections.
While you are at it, check the whole wiring harness to see if there are any rub points that broke a wire. I've never seen this happen before, but there is always a first. If you've done all that and there is still no spark, then you could have a problem with your stator. That is the unlikely culprit, so I would check my connections first.
Good Luck and let us know if you have any luck.
Old May 23, 2004 | 10:18 PM
toocko's Avatar
I looked over the wires and the light switch. Looks like it is my switch. So I will post a new thread to see if anyone has one to sell.
MooseHenden
Family ATVing Photos
Sep 20, 2015 04:14 PM
Alex Rodak
Sep 13, 2015 12:30 AM
Alex Rodak
Sep 12, 2015 09:39 AM
Alex Rodak
Sep 11, 2015 11:42 PM
Steeldon
Sep 9, 2015 09:38 AM
