high compression 727
Old May 17, 2004 | 12:46 AM
sandRappy's Avatar
Default high compression 727
Ooops, sorry about about the blank post. Anyway what I was wondering is if anyone with a 727 or 730 that has high compression pistons have had any problems with them?
I finally got mine together and some time on it. Then I have been messing around with the carb setup. So the other day I finally get the carb tuned into where I am not lean and I can ride it hard. After a short run seeing how it runs I bring it back to the shop and it has oil all over the engine. Long story short, one stud that holds the jug to the cases pulled out the threads, while the other rear stud was loose.
I have no idea why this happened. I am only running a 12:1 JE, but apperantly that is a little to much compression for it to hold. I know those studs were torqued correctly. One stud was completely stirped out will the other rear stud was very loose compared to the front two studs.
Also since this is the first time I have riden the bike hard I noticed it was vibrating really really bad. Is this normal with a 730? I had the crank reblanced with the new piston and rod so I thought it would run smoother then it did stock, but it feels like there is no counter balance in the thing. Even though the jug was held down by only three bolts I don't think is should vibrate like this.
Is anyone running a 730 with out heili coils (sp?) I was because I didn't think I would need them.
pgamboa
Dec 24, 2023 11:52 AM
2quiker
Mar 22, 2022 08:36 PM
bvolks
Sep 13, 2015 12:57 PM
Steeldon
Sep 9, 2015 09:38 AM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
