Belt jumping noise?
Old May 17, 2004 | 05:57 PM
Davinator's Avatar
Default Belt jumping noise?
I now have a noise coming from my belt\kebc area that I’m not sure about. When I’m in low gear and let off the gas it makes a belt ratcheting noise. It sounds like it’s jumping the groves on the belt. Is this the drive clutch bearing going bad? I replaced the belt and the noise stayed. Don’t use low that much, so don’t know how long it’s been doing it.
DG Holeshot
DG Snorkel
K&N Filter
Dial-A-Jet-(GONE)
Supertrapp IDSX exhaust
Primary Dalton Plain\white spring
Secondary EPI black spring
P-700 Belt
28” Mudlites on C's
Odyssey 925 Dry cell battery
Warn 4000 winch on front
Warn 2500 winch on back
Headlight mod
Back-up lights
Old May 17, 2004 | 06:22 PM
Kawi650's Avatar
is it your engine brake bearing? More noticable in low than high.
Old May 17, 2004 | 06:27 PM
TriumphDude's Avatar
Check your shifter linkage. It needs adjustment. It has been posted by others before. It fixed mine. It is an easy adjustment.
Old May 17, 2004 | 06:51 PM
newbeatle's Avatar
If it sounds kind of like gears grinding... it is, & TRIUMPH is correct... if this is the case, also check your motor mounts, often it is loose mounts & a slightly off position motor, that causes the shifter to need adjustment...
It is also possible for the KBEC bearing to make a similar noise, & one persons description of a noise, will be different than anothers... My KBEC bearing made more of a whining noise, rather than a ratcheting type noise...
Jeff Roper
Feb 1, 2022 11:48 AM
mrtidy
Feb 3, 2016 05:00 PM
Ahtatu
Sep 28, 2015 12:14 PM
black_thunder
Sep 22, 2015 07:59 PM
