tires and tire size for 02 Prairie
Old May 18, 2004 | 12:25 AM
ydopen's Avatar
Default tires and tire size for 02 Prairie
I need a tire with a lot more bite than stock tires. I have read that mudlites are a good all round tire and mudbugs are also good. The main question is how big? Some people say 26" is great, others say 27" is better for clearance. I was thinking of 27-10 in the front and 27-12 in the back? Is this a good choice in tires and sizes? P.S. I ride in every type of terrain.
Old May 18, 2004 | 12:55 AM
Crawdaddy's Avatar
I have 27x10 front and 27x12 in rear Titan 589's awsome tire very thick side walls smooth ride and best of all awesome traction in the mud.
Old May 18, 2004 | 08:23 AM
newbeatle's Avatar
YDO... you can easily fit those tires in that size on your Prairie... however you should determine the tire & size, by the type of riding you do... If you like to "rip" around, & ride sporty, then, IMO, stick with 26" or so tires... generally the larger the tire, the heavier they are, the tire weight willn effect ride quality, acceration, top speeds, etc... I ran a set of 26" Mudrunners for a little over a year, & still had the sportiest of the utility quads, of the guy's I ride with... if you enjoy a more casual pace, you should be fine with a 27" tires... you'll find that the Mudlites, offer good traction, but don't last very long, because of the softer rubber compound, & the skeletonized lug pattern, if you enjoy ripping around, or spend much time on the roads / gravel, etc. of the 2 tires you mentioned, The Bugs will likely outlast the Lites, even though the Lites you are looking at, have the deeper tread pattern ( being 27", over the 25" )
unless you do alot of mud only riding, you may also want to look at one of the radial tires, they will provide more than enough traction, in everything but deep or sticky mud...
Old May 18, 2004 | 08:58 AM
RaaaaddddChad's Avatar
I have a set of 26" Bearclaws on mine. They are a really good all around tire. I love them. I would like a set of 27" tires now though because I find what I do with it, I need a little more clearance. But otherwise I have no regrets at all. Check my pics to see how they look.
Old Jul 7, 2004 | 01:48 PM
IfUFindAGurlWhoWillWashUrBikeMarryHer's Avatar
Itp 589's are great tires. I have some brand new 28 inch 589's for sale on Itp steel rims that didn't fit my weeler but they will fit kawasakis with the bolt pattern 4/137 if any one is interested.
Bratman2
Aug 6, 2022 01:42 AM
velcro7279
Aug 24, 2015 01:15 PM
2007 Grizzley 450
Aug 13, 2015 06:33 PM
rcappie4
Jul 18, 2015 07:51 AM
coolguy420
Jul 9, 2015 09:54 PM
