Drag race reaction time questions ...
Old May 18, 2004 | 09:28 AM
newbeatle's Avatar
Default Drag race reaction time questions ...
I'm currently going to the drag strip, to measure gains provided by different tires, clutching, & performance modules... is it safe to say that if I subtract my reaction time, from the 60 ft & 330 ft times, that I will have the actual time it took for my quad to go those distances ( basically eliminating the human error... for aynalitical purposes ) ??? I.E. if I had a reaction time of .832, & a 60 ft time of 1.929, that, the time it took my quad to go to 60 ft, from the time it began moving, was 1.097 seconds ??? or is there something I'm missing here... If I can use this formula, it will make it easier to actually compare times of different performance mods, by removing the human error ????
Old May 18, 2004 | 09:46 AM
Prairiewrench's Avatar
Nope, your actual distance time should not start till you have launched! Your reaction time is the time it takes from when the light goes green to when you break the start line, when you break the start line then your distance time starts!
Old May 18, 2004 | 09:50 AM
newbeatle's Avatar
JIM... thanks... pardon my ignorance... so then there is no human error in my times off the slips... cool, even easier to compare... thanks
Old May 18, 2004 | 07:00 PM
scrambo's Avatar
New Beatle...I'll take it one step further. On an actual drag strip you have two lines before the starting line, Prestage, stage, then start. You can do whats called a deep stage and lesson your reaction time but you also run the risk of red lighting. Deep stage is where you roll into the lights until the prestage lights goes off, thus getting you closer to the starting line. Even so, this still doesn't start the time clock until your tires actually cross the starting line.
MikeyBoyesq
Nov 27, 2020 02:44 PM
Rtgjje5
Jun 16, 2015 08:23 AM
Jun 10, 2015 11:33 PM
blackmagic
Feb 26, 2000 09:27 AM
