Kodiak Stalls when giving it gas
Old May 19, 2004 | 12:58 PM
Yagimo's Avatar
Default Kodiak Stalls when giving it gas
Cranks up and idles fine. Give it any gas and it stalls out. pulled air filter cleaned it, gas line is not cloged. what elso could it be? I was pulling a dounut in sand when this happened.
Jon
Old May 19, 2004 | 01:16 PM
sAyIt_fmf's Avatar
Sounds like it's starving itself of fuel. Any chance some of that sand made it's way into the carb? A clogged pilot jet will do that.
Old May 19, 2004 | 01:23 PM
AlaskaBoy's Avatar
Yagimo,
This may sound stupid, but is your gas cap vent tube pinched?
AlaskaBoy.
Old May 19, 2004 | 02:10 PM
Yagimo's Avatar
The gas vent tube is not pinched. Is there any recomendations on how to clean the pilot jet?
Old May 19, 2004 | 02:50 PM
sAyIt_fmf's Avatar
There is really only one way to clean the pilot jet out...that involves removing the carb from the quad and getting to the float bowl.
I should say that I am not familiar with the quad in question...so I'm not sure what kind of work is involved with removing the carb. It seems to me that the utility quads always seem to have a ton of plastic covers in the way of everything.
Old May 20, 2004 | 04:15 PM
Yagimo's Avatar
well i already have access to the carb, seeing how i already pulled all the plastic off. once i have the jet out how should i clean it?
Old May 20, 2004 | 04:17 PM
sAyIt_fmf's Avatar
If you have access to compressed air...that is the best way to do it...make sure you can see light through the jets
Be careful with carb cleaner...it can damage rubber and gaskets
Old May 20, 2004 | 06:04 PM
wolverine68's Avatar
If it is idling fine then I would guess a main jet blockage as opposed to a problem with the pilot.
Old May 20, 2004 | 07:50 PM
zslate's Avatar
that's what my warrior was doin' and I took it in *shop* they cleaned the carb and put a gas filter on it!
Old May 20, 2004 | 09:09 PM
87warrrior's Avatar
I had a similar problem with my warrior and it turned out that it was time to clean the carb. went and bought some spray that you just spray in the carb and fixed it right up. dont even need to take the carb apart, u just go in from the air box!
