110 VP gas and plug readings
Old May 21, 2004 | 02:54 PM
caliraptor's Avatar
Default 110 VP gas and plug readings
I tried some 110/91 mix last night with a new plug, rode around for 2hrs and pulled the plug and it looked like new. WTF? Is it possible to read a plug using 110? Im gonna try straight 91 w/o octane boost like I usually do and see if its any different.
BTW...
I put in 185/190 DJs cuz I was running a bit lean, thats why I wanted to do a plug check.
Old May 21, 2004 | 04:44 PM
LOWBOWTIE's Avatar
I get a nice reading from using VP110. It's alot better than the 76 I used to use!IMO
Old May 21, 2004 | 04:49 PM
RoostItUp's Avatar
if it looked new your runnin way lean, lean enough there is no carbon build up on the ceramic.
Old May 21, 2004 | 05:59 PM
1BADRAPTOR's Avatar
i would stay with the 110 or even higher, i would not try the 91 in a built motor, even semi built ..JMO
I am using VP c14 with my raptor and that is at 114 octane..
Old May 21, 2004 | 06:23 PM
caliraptor's Avatar
Damn, 185/190 jets and Im lean? OMG, I hope I havent messed anything up! Im gonna bump it up to 195/200 then[img]i/expressions/face-icon-small-shocked.gif[/img]
Old May 21, 2004 | 06:30 PM
Dfitz's Avatar
1bad are you testing this weekend?[img]i/expressions/face-icon-small-smile.gif[/img]
Old May 21, 2004 | 07:45 PM
1BADRAPTOR's Avatar
[img]i/expressions/face-icon-small-wink.gif[/img] if my pipe gets here...[img]i/expressions/face-icon-small-mad.gif[/img]
Old May 21, 2004 | 07:55 PM
RaptorOwner's Avatar
Mr horsepower..... Come on, it should have been there all ready. Call them up and have them email or fax it to you....... hehehehe
Old May 21, 2004 | 09:17 PM
2004LEBANSHEE's Avatar
Dont switch to octain booster that stuff is $hit. VP is really good. It will burn a lil cleaner then regular fuel too.
Old May 21, 2004 | 09:23 PM
ANNIHILATER's Avatar
No Mercy Racing! Got NOS?
You will lose power from octane booster and It might gum up your carb. 110 octane should give you a greyish tan reading if tuned right. Kill the motor while the bike is under a load and then look at your plug.
