I know, Another YFZ jetting ?
Old May 22, 2004 | 07:21 PM
TRLYFZ450's Avatar
Default I know, Another YFZ jetting ?
I did a search but could not find the info i needed. I have a stock pipe with 5, 1/2 inch holes drilled into the mid plate in the pipe (this plate must force the exhaust around to the outside of the pipe) and the spark arrestor is out, no air box cover, cam mod and the GYTR air filter. I have a 170 main jet, The YZ needle (4th) and a 45 pilot jet, 3 turns out on the airscrew. My? Is that at 3/8 throttle it pops a little (free revving no load) but nowhere else. When driving at same throttle position it is fine. Does this mean the jetting is close enough or should I go with a 48 pilot jet? Thanks for the help.
Terry
Old May 23, 2004 | 12:40 AM
TRLYFZ450's Avatar
Anyone have any idea?
Old May 23, 2004 | 01:01 PM
DirtDragon's Avatar
First thing to do is put the needle on clip 3, then put in the 48 pilot and 1.5 turns on the screw. If it still pops alittle then adjust the screw until it is gone.
Old May 23, 2004 | 01:43 PM
TRLYFZ450's Avatar
Thanks i will try it.
Old May 23, 2004 | 06:16 PM
pudljumpr's Avatar
The yfz needs it jetting runs to be under a load, otherwise yes, you get the pop burble if you just rev in N. The best way to do jetting is to set the needle on 3 or 4, whichever you need for some more mid range fuel, and adjust your main and pilots from there. Always easiest to start rich and back down one size at a time until it stops bogging on top. Rich is always easier to tell than a lean condition.
ReconBayou
Oct 31, 2022 05:37 PM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
XxS0ccerstarxX
Sep 8, 2015 12:02 AM
