BAD NEWS!
Old May 23, 2004 | 01:51 AM
hondaguy2's Avatar
Default BAD NEWS!
today i adjusted my vavles on the big bear. At first the big bear had a slight ticking so i thought i should adjust them. well i put the intake at .006 and we left the front cause it was good. we put the cover on started it up and it just ticked really loud. we tried about 8 other adjustment. it still ticks not to bad but atr the top end it doesn't run right. what have i done wrong. need to get it fixed before this weekend for our big ride[img]i/expressions/face-icon-small-sad.gif[/img] PLEASE HELP ME
Old May 23, 2004 | 08:39 AM
enFORCER's Avatar
Default BAD NEWS!
Well it might not be your valves. You might want to take a look at your cam chain, take the cover off and look to see if the chain is stretched out, or if there is a excessive amount of slop in the the chain. This some times will cause the problem you are having and no amount of valvle ajustment will correct it.....
Old May 23, 2004 | 08:57 AM
sixsixT's Avatar
Default BAD NEWS!
Make sure your not adjusting the valves at the top of the exhaust stroke. If the clearance on the exhaust valves were good that's probably not the case but you never know.
Old May 23, 2004 | 01:15 PM
hondaguy2's Avatar
Default BAD NEWS!
we adjusted them at top dead center. i think its just a matter of fine tuning
Yamaha Side by Sides
Sep 8, 2015 01:43 PM
Aug 18, 2015 01:00 AM
Jul 21, 2015 03:03 PM
WilliamBos
Jun 11, 2015 05:57 PM
