help !!!?!!!
Old May 23, 2004 | 08:20 PM
xraptor660rRider's Avatar
Default help !!!?!!!
ok my raptor has a small oil leak no big its getin fixed so i went up a couple days ago to show a kid where the trail it an it died an it wont start so he hooked on it with his kodiack an started up but now alll i can do is pop start it not electric do you know wat my problem is ?
Old May 23, 2004 | 09:45 PM
n e 1
Old May 23, 2004 | 10:05 PM
sixsixT's Avatar
Do you hear it clunking, clicking, wanting to turn over at all. It could be a relay, starter, oneway, battery or one of the safty switches.
You need to include a little more detail if you want a good answer.
Old May 23, 2004 | 10:08 PM
warrior387cc's Avatar
ya what have you tried so far you could try juicing your battery and if thats not
it work you way forward next chck your connections then the relay or whatever
its called selinoid then the start button , and of course starter connections
and if none of that is it get your starter load tested at the local auto shop.
Old May 24, 2004 | 08:07 AM
it doesnt do any thing my lights work though
Old May 24, 2004 | 09:37 AM
sixsixT's Avatar
Try a jumper across the relay and see if the starter works.
Old May 25, 2004 | 03:55 PM
warwgn's Avatar
check the fuses too.
Old May 25, 2004 | 03:57 PM
pinheadedjoker's Avatar
yeah check fuses and wiring from teh startor switch and do a load test on the startor
