steering help
Old May 24, 2004 | 08:34 PM
hondarider300's Avatar
Default steering help
ever since i crashed my 300ex into a curb, when ever im going straight it wants to turn to the right. If i take my hands off my handle bars they move to the right and it turns to the right. (just a little bit, the handle bars move over an inch or 2) How do i straightin that out. thanks
Old May 24, 2004 | 08:56 PM
HondaPa14's Avatar
my best advice is dont cross faulk road if your not expierence enough or man enough for the task
Old May 24, 2004 | 09:23 PM
TractorPacker's Avatar
Do you have a balloon?
You probably bent a tie rod. If thats the case change it , because once bent they bend even more. If its not that you will need to readjust the tie rods. Stand it up and see if you see something bent, one side to the other.
Old May 24, 2004 | 10:02 PM
are the tie rods the bars that connect the wheels to the steering stem?
Old May 24, 2004 | 11:32 PM
Yes,to adjust them loosen both nuts, one is backwards thread. Then turn the rod in or out and it will move the tire accordingly. Ithink the book says to have about a half inch tow in. That means the front of the tires are closer then the rear or the same tires by about a half inch.
Old May 25, 2004 | 04:31 PM
found out what the problem was. One of the tires had alot more air then the other. its fixed now thanks for the help anyway
Sep 30, 2015 01:37 AM
35dodge
Sep 29, 2015 09:40 AM
Todd C Wadas
2) Chassis problems..
Sep 23, 2015 11:31 PM
MikeyBoyesq
Sep 7, 2015 10:44 PM
Logan Collins
Sep 5, 2015 08:03 PM
