spring?
Old May 26, 2004 | 12:51 AM
Crawdaddy's Avatar
Default spring?
What is the difference or benefits of replacing your drive or secondary springs? I have a 02' P650 with 28x12 589's will these mods give me more take off power. My quad is used for primarily hunting and trail riding and occasionally towing.
Old May 26, 2004 | 06:42 PM
Crawdaddy's Avatar
Default spring?
It is hard to believe with all the info in this forum nobody can help with this ? I would appreciate some info if anybody has some input. Thanks
Old May 26, 2004 | 07:53 PM
kawiyowee's Avatar
Default spring?
The secondary black spring is to prolong belt life. The primary replacement spring from EPI or Dalton is for more power and acceleration in the low to mid range.
I put the EPI black spring on a few months back. Called EPI last week and talked to Krista about the primary spring. She asked what size tires, 25" mudrunners, and recommended the pink spring for my quad. It is very similar to the stock spring at idle, but engages better than stock at higher rpms. She did not suggest a clutch kit to me since I already had the black spring. Also, and I hadn't hear this before, she suggested replacing springs once a year since they fatigue a bit with the constant flexing while riding.
I recommend you call EPI at 218-829-6036. Call Dalton too if you want. I haven't put the pink spring on yet, will install it next week and post results.
Old May 26, 2004 | 11:01 PM
DocPoof's Avatar
Default spring?
I use a Dalton blue..very simlilar to stock stall....but a HUGE difference in acceleration...will get you to top speed alot quicker..
At least on my V it does....the stock acceleration used to peater out around 40mph and slowly go up from there...no more with the dalton blue...
Secondary spring basically effects how hard the clutch will grab the belt....in lay mans terms
Old May 27, 2004 | 01:00 AM
markdf's Avatar
Default spring?
Crawdaddy,
There's a forum member, KevinM, that keeps a primary spring table web page. The URL is http://www.700v.com/id33.htm.
He's tested a bunch of springs and provides footnotes about the benefits/drawbacks of most springs. I found it very useful.
Hope this helps.
Mark
Old May 28, 2004 | 12:07 AM
Crawdaddy's Avatar
Default spring?
Thanks to everyone for the info it was very helpful.
Old May 28, 2004 | 12:14 AM
RedGoblin's Avatar
Default spring?
Hey Kawiyowee, please don't forget about those Pink spring results. Have you thought about the Dalton Plain/White Primary? My choice would be between these two springs.
shimanok2
Jan 29, 2016 07:37 PM
brinkkl2000
Oct 16, 2015 11:08 AM
chuck1177
Aug 11, 2015 03:22 PM
Wnthunting
Jul 9, 2015 03:02 PM
Mphillips
Jul 2, 2015 07:20 PM
