guys can you help please??
Old May 29, 2004 | 12:05 PM
mabell1's Avatar
Default guys can you help please??
i posted this question last night in the bombardier forums and havent received any help yet. (i know i am impatient) My brother in law has a 04 outlander 400 and it will not idle. if you put the choke on about half way it runs fine?? any ideas of what could be wrong?? it has ran fine up until the other day. he said he didnt go through any water. thanks again
Old May 29, 2004 | 12:09 PM
CED's Avatar
CED
Sounds like the pilot circuit in the carb may be plugged up with some trash.Take it apart and clean the pilot jet,and see what happens.
Old May 29, 2004 | 01:40 PM
DaSandBomb's Avatar
Check and make sure the Air filter is on properly, look for loose connectors on the air intake tubing and Carb mounts. If you choke it and it runs better while warm, it's running lean. If you do take the carb off (last resort), check that the float is operating properly. Pull the gas line off the carb and run some gas into a can or jar while turning the shutoff on/off. Does the fuel flow properly? if not clean the tank and filter if it has one. Does the gas look watered down? Sometime water in the tank or Carb bowl will do this so drain the carb bowl as well. Have you checked the Plug? Try replacing it and see if this helps.
Don't give, keep trying things and you will learn as you go.
bafisher1986
Jul 21, 2015 04:12 PM
rcappie4
Jul 18, 2015 07:51 AM
Robinhood
Jul 13, 2015 09:13 PM
Edgeslade
Where to Ride
Jul 10, 2015 05:08 PM
