oil ratio for modded Kasea.......
Old May 29, 2004 | 09:21 PM
TNTQuadJunkies's Avatar
Default oil ratio for modded Kasea.......
oil ratio question for Kasea Guru....
We have a Kasea 90 with a HC piston,(12:1) aluminum rod, CDI to 12,000 Bored 40 to become a true 90,then 10 over .Ported head,28mm flatside Carb, Carbone fiber reed cage full clutch mod, ok here is my question.....
The racing Co. that built it says we should run Opti fully synethic 80:1 with straight c-12 or min. 106 octane
I dont mean to second guess them, but holy cow.....80:1???!!!
Anyhow, were also looking for a differernt oil that would work well with the Kasea since this oil is hard to find around here ......Any suggestions????
Old May 30, 2004 | 11:29 PM
spike99's Avatar
80:1??? I would say, "Holly Cow" as well. With Oil Injection system removed, everyone starts at 32:1 then "tweaks" their ratio based on their specific brand of oil and several Plug Readings. I've heard of 1 guy running 40:1, and that's only for short drag races. Most are at 28:1 to 34:1 (average at 32:1). At 80:1, it soulds like their are trying to make another customer out of you.
Old May 31, 2004 | 01:39 AM
confusedbuyer's Avatar
I'm wondering if "80:1" is an oil type, or synthetic oil characteristic. My Amsoil Sythentic bottle says something like 100:1 on the bottle, but it doesn't necessarily mean that's what I should mix it at. I think it's just an oil characteristic. I'm really glad you second guessed it, because it can't be right, especially with all your performance mods. I'm thinking 32:1 with all the mods you've done. The WORST you'll do is foul the plug, and then you could lean it out. If you err the other way, you'll blow apart the engine "toute suite" (hey it's Canada, we're bilingual, it means "right now").
I agree with SPike99, try a few tanks of 32:1 and lean it out from there after checking your plug.
Old May 31, 2004 | 02:43 AM
we ran 32:1 with only a pipe. Im not sure if this spcific oil has anything to od with it or not.....Ill ask them again on Tues. I dont want them to think I dont trust here best judgement or anything,just trying to understand the mix I guess.......
Ive gotten mixed reviews,some ay its fine.others say no way.......lol Tina
Old May 31, 2004 | 11:06 AM
geo's Avatar
geo
For what it's worth, I've been running the same piston (Airsal single ring design) for the last year on both of my kids' minis with no problems at 40:1 (Cam2 + Klotz HP50).
I inspected both about a month ago, and the bores, skirts, and rings look perfect. Good compression and power. Plug fouling has never been a problem (I probably just jinxed myself!).
I know of test engines that have successfully ran at 100:1 (the company i work for manufactures two cycle oil, among other things). I work the engineering end, but from a commercial standpoint there's probably some wisdom to the fact that you sell more oil at 32:1.
Old May 31, 2004 | 11:41 AM
Thank you for your replies!!........We'll richen it up a bit I guess and see how it goes....[img]i/expressions/face-icon-small-wink.gif[/img]
Old May 31, 2004 | 12:19 PM
Bluetickracing's Avatar
I think 80:1 will scatter the motor in no time! My son has a Polini x3 works dirt bike. It has a 12:1 piston,and a 14,000 rpm cdi, and has 13 hp stock. The factory oil ratio mixture calls for 110 oct race fuel mixed at 40:1. This bike has never blown , plus the piston looks brand new.But you have to use the best mixing oil you can find. I will only run Maxima super M or Maxima 927 oils in all my 2 strokes. I also run a 40:1 mix in his quad.
_______________________
"Keep it pinned to win"
"Don't ride faster than your Angel can fly"
#838-01 Polini x3 works-Michaels
#838-01 Husqvarna cr50 jr-Michaels
#838-04 Arctic Cat 50-Michaels-Kpii Exhust,Malossi cdi,Malossi clutch kit,Malossi reed block and reeds,Twin Air filter and Moded air box,Rebel Gears,Acerbis hand guards,ProDesign tether,Douglas alum wheels and SnowHogs tires.
#839-04 Suzuki DR-Z125L-Justins
04 Yamaha Big Bear 400 4x4-mine
_________________________
The money I spend on his bikes and quad seems like a $$$$$$$$$$$$$$$$$$$$ bucks!
The look on his face just after smoking the whole entire field in a race[img]i/expressions/face-icon-small-tongue.gif[/img]RICELESS!
We always like to thank Michaels sponsor Dirt Works cycles and ATV's . Text
Customer Service #1
May 15, 2020 08:46 AM
rockinkgin
Sep 25, 2015 01:52 PM
Sep 23, 2015 06:23 AM
PrairieDog126
Sep 16, 2015 01:33 PM
1ArmBandit
Sep 8, 2015 08:59 PM
