Got a flat, what to do?
Old May 31, 2004 | 05:45 PM
BigChris's Avatar
Default Got a flat, what to do?
Heyy,
almost made it a whole year w/o a flat, but yesterday i got one
My lakota tires are tubeless, and the actual hole isnt very big, but its on one of the tread designs, i manages to put 3(!) plugs in but it still leaks.....so now what should i do......what stuff do u guys reconmend i should use/get?
i think i have to patch the inside of the tire, but what should i use?
thanks alot!
~CHRIS~
Old May 31, 2004 | 06:00 PM
Kawi650's Avatar
inside tire patch will work fine... you also could valcanize it.
Old May 31, 2004 | 10:39 PM
kawakasi's Avatar
Slime
Slime I tell you
Dont put a patch on it
Forget about puttin a tube in it
I hit a culvert last fall...gotta 3/4 inch gash in my sidewall
Put 4 plugs in it and it dont leak a bit
But of course I have almost a quart of slime in it.
Go out and getcha a gallon.....little less than a qt. in the fronts
Little more than a qt. in the rears
Old May 31, 2004 | 11:09 PM
reconman2003's Avatar
slime deteriorates the inside of your tires
Old May 31, 2004 | 11:58 PM
CrekRunner's Avatar
If 1 plug wont do it then it is a big hole. Put some rubber cement on the plug and it should be fine.
Old Jun 1, 2004 | 12:53 AM
hondabuster's Avatar
My experience with slime, is that it works excellant. I put some in a flat three years ago, and it still is sealing just fine.
Dammar
Apr 20, 2016 06:03 AM
MikeyBoyesq
Sep 22, 2015 10:02 AM
caveeagle
Sep 19, 2015 01:20 PM
essonlaker
Sep 10, 2015 01:12 PM
MikeyBoyesq
Sep 7, 2015 10:44 PM
