how can eton 150 go faster
try letting more air into the motor + change jets then try adding alittle more gear with the eng. mods it should give you alittle more power to pull the taller gears. I do see that the 150's are iether out of gear or the clutches are fully shifted out.
thank you how do u change the jets it is an auto matic and plus i dont want to get into anything that technical so gearing is not a good option just kicking arouns some ideas thanks cody
