banshee jetting with fmf
Old Jun 2, 2004 | 08:12 AM
bansheetwins's Avatar
Default banshee jetting with fmf
running fmf fattys on stock motor 26mm ,k&ns,running 290s now seems like its slugish on the bottom....any suggestions??good mid and excellent topend
Old Jun 2, 2004 | 09:39 AM
sAyIt_fmf's Avatar
You mentioned the mains? Did you change the pilot jet or needle position?
And what is your elevation?
Old Jun 2, 2004 | 09:47 AM
moved the needle clip to 4th stock pilots
Old Jun 2, 2004 | 09:50 AM
not shur on ele. Ilive in nortern minnesota.
Old Jun 2, 2004 | 10:00 AM
sAyIt_fmf's Avatar
I just put the fatty's on my banshee. There was a little piece of paper with the pipes that gave these instructions: (take into acct. that not all bikes are the same).
Stock needle/3rd clip
280 main
30 pilot
about 2 turns on the air screw.
I am at about 500 ft elevation and the bike runs great. I have not fouled a plug in the last 4 trips out...and these are usually full day rides.
Just thought I would share.
Old Jun 2, 2004 | 10:16 AM
thanks for the info ill try that..
Old Jun 2, 2004 | 10:17 AM
Hiram's Avatar
Fatties like a big pilot jet somewhere around 30 - 32.5's check to se what you have now, as it seems it needs more fuel on the pilot circuit.
Old Jun 2, 2004 | 10:21 AM
as soon as i moved the clips I gained alot of top but the bottom is bad im running 25s for pilots
Old Jun 2, 2004 | 06:15 PM
2004LEBANSHEE's Avatar
I move the needle until it bogs then back off one.
Old Jun 3, 2004 | 10:10 AM
sAyIt_fmf's Avatar
I still think you will get good results from a larger pilot jet.
start around 30
ReconBayou
Oct 31, 2022 05:37 PM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
XxS0ccerstarxX
Sep 8, 2015 12:02 AM
