larger jet in right or left carb on raptor
Old Jun 2, 2004 | 07:18 PM
ccgrady's Avatar
Default larger jet in right or left carb on raptor
does the larger jet go in left or right carb when sitting on it
Old Jun 2, 2004 | 07:22 PM
HoundDog06's Avatar
The left side should be jetted roughly two sizes larger than the right due to it feeding two valves and the right feeding one.
~HoundDog
Old Jun 2, 2004 | 07:31 PM
Stoppie's Avatar
Uh ohhh. I have a 145 main in my left and a 150 in my right. It seems to run fine though? Could this be bad in the long run?
Old Jun 2, 2004 | 07:37 PM
ccgrady's Avatar
i have called four dealerships and its 50/50 on which one
Old Jun 2, 2004 | 07:39 PM
Stoppie's Avatar
Wait, are u looking at the quad from the front or sitting on it when you talk about left and right?
Old Jun 2, 2004 | 07:54 PM
ccgrady's Avatar
sitting on it. looking at the manuel while sitting on it the smaller jet goes in the left or the carb with the idle control. this is the way i read it but could be wrong
Old Jun 2, 2004 | 08:04 PM
ccgrady's Avatar
i found my old yosh instructions and it says right larger but doesnt say how looking at it.
Old Jun 2, 2004 | 08:06 PM
pinheadedjoker's Avatar
if its in place and u are sitting on it it will be the left one if its flipped over its the right.
Old Jun 2, 2004 | 08:57 PM
ccgrady's Avatar
i called yosh and they said the right carb while sitting on it and i also called alba and they said the same thing. the manuel says the carb with the idle is #1 and the other one is #2. Carb 1 says 140 and carb 2 is 145. carb two is right side or reverse **** side.
Old Jun 2, 2004 | 09:04 PM
Stoppie's Avatar
I guess im ok then.
