GO FAST tips for a scrambler 400 2x4
Old Jun 2, 2004 | 09:30 PM
proXpilot's Avatar
Default GO FAST tips for a scrambler 400 2x4
alright guys i know you got some tips to make these things go fast! heres my dream tell me if im close. it's already
.60 over, v-force reeds, 38 mm flatslide carb, uni filter, epi clutch kit, dg silencer. now id like to get the Hotseat pipe and silencer, hypershift clutch kit, and cut the head .30 or so. what else can i do?
Old Jun 2, 2004 | 09:59 PM
tbsleeper's Avatar
first get the pipe and silencer and then get it ported which will get you more than boring and milling the head and getting new reeds all together.
Old Jun 2, 2004 | 10:52 PM
POLARISFREAK's Avatar
My preference would be hpd or Rick Ritter for the bike and Bubba297 does a mean port job for reasonable prices!
Old Jun 2, 2004 | 10:56 PM
proXpilot's Avatar
rick ritter have a website?
Old Jun 2, 2004 | 11:00 PM
Troyer23J's Avatar
http://www.rittercycle.com/
I would stay away from people besides RCR, HPD, HotSeat, AAEN. Bubba297 for porting also.
I wouldnt recommend boring until it needs it, save them, you will need them eventually. Upgrade the piston to a Wiseco while you are doing these things
Old Jun 3, 2004 | 09:59 AM
scramblered's Avatar
you did loose a bit on top with .060 over,you should get it ported to acheive the potential you got on bottom end with the big bore,it is always to choose a brand wich you'll got the pipe from,if you're looking fdor hot seat pipe,go for hot seat porting.tmx 38 is excellent for trail mods use.cutting the heads mean you need higher octane gas then...
the epi kit is a pretty OVERALL clutch kit,if you want something truly
to your riding style,get one of those:hpd,hot seat,aaen,rcr,cpi.
Old Jun 3, 2004 | 12:08 PM
kyxplorer's Avatar
If you want to still run premium gas then take .020 off the head and i premix Klotz super tech 44:1. If you know a good mechinist i would turn the flywheel down as much as possible but make sure they balance it. I had to go to Polaris snowmoble motor mount 90+ durometer to stop the engine torque. Mods: air box by cutting the center section out of the top and bottom; AAEN mid range pipe and silencer; Carb : 390 main jet and 35 pilot; Heelclicker primary clutch kit (scrambler version) with a stock spring and 2:2 setting for the secondary;Napa Gates belt 19AT4090;Pro circuit bars; F1 superbike chain; Budda's port and polish will make it pull hard from bottom to top. On mine a set of Yamaha Warrior nerf bars and foot pegs really worked out good. hope this helps some.
later
hunt
Old Jun 3, 2004 | 02:35 PM
tbsleeper's Avatar
hey ky how are you making over 70 hp????
Old Jun 3, 2004 | 05:00 PM
proXpilot's Avatar
i was thinkin about gettin a real hair in my @ss and getting the hpd powervalved 415 kit but i dont think i have that kind of bread .
Old Jun 3, 2004 | 05:06 PM
CED's Avatar
CED
The full race mod is half the price of the power valve.Then get it on alky ,you won't be dissappointed.[img]i/expressions/face-icon-small-happy.gif[/img]
