86 250r atc carb
Old Jun 3, 2004 | 09:34 AM
hancho's Avatar
Default 86 250r atc carb
I just got an 86 250r but is running veary fat. It had a 150 main jet so i keep gong down till it is running good, but that was all the way down to a 118. I know stock is around a 148. The atc has a FMF pipe FMF reads (new) stock cage and a reed spacer. I donot know anythig about the bore thow. With a 118 it runs good not to lean been doing plug checks. So last light i took the carb off to see of I could see anythig wrong with it and there was nothing. I pulled it all a part sprayed brake cleaner therow all the holes no holes where pluged up. But I still want to get a new carb should I go back with the PJ and if so what MM or should i change? and what MM. Thanks for your help
Old Jun 3, 2004 | 04:38 PM
HA2's Avatar
HA2
how do your reeds look? stock is 145 main and with the reeds and a pipe you should still be around stock.
Old Jun 3, 2004 | 04:40 PM
HA2's Avatar
HA2
38MM air stryker if you plan on going bigger bore or porting. i ran mine on my ported 250, ran like a champ.
Old Jun 3, 2004 | 07:15 PM
dragracer789's Avatar
Hey man my 1986 TRX is the same way. Stock is 145, and Im down to a 130! At least I dont feel left out anymore lol. Anyways, The keihin PJ carb sucks. Go with the PWK A/S. I would get the 36mm for all around riding, and like HA2 said get the 38 if your going to be adding any mods to it. By the way, you will not regret getting a new carb!
Old Jun 4, 2004 | 09:31 AM
hancho's Avatar
thanks for the help I orderd a 35mm PWK lastnight
Old Jun 6, 2004 | 12:37 AM
atcsteve's Avatar
be careful not to lean it out.try removing the spacer plate,with no big modsyou wont need it.
GregM
Jul 29, 2015 09:41 PM
ghost civic
Jul 27, 2015 03:15 AM
Dustinyoungs
Jul 24, 2015 07:18 AM
Aitch
Jul 21, 2015 09:40 PM
CRamshaw777
Jul 18, 2015 05:46 PM
