250r carb help
Old Jun 3, 2004 | 09:46 AM
hancho's Avatar
Default 250r carb help
I just got an 86 250r but is running veary fat. It had a 150 main jet so i keep gong down till it is running good, but that was all the way down to a 118. I know stock is around a 148. The atc has a FMF pipe FMF reads (new) stock cage and a reed spacer. I donot know anythig about the bore thow. With a 118 it runs good not to lean been doing plug checks. So last light i took the carb off to see of I could see anythig wrong with it and there was nothing. I pulled it all a part sprayed brake cleaner therow all the holes no holes where pluged up. But I still want to get a new carb should I go back with the PJ and if so what MM or should i change? and what MM. Thanks for your help
Old Jun 3, 2004 | 10:38 AM
HondaMan85's Avatar
As for your smaller main jet, it could be due to your altitude. Air thickness has a lot to do with your jetting.
Old Jun 3, 2004 | 12:04 PM
BrocksZ's Avatar
i went from a 39mm to a 36mm and improved the bottom end a lot!!!!!!!!
Old Jun 3, 2004 | 08:27 PM
bansheeesmoker's Avatar
this may sound weird but one time i over oiled my air cleaner and it did the same thing becuase the oil went to the motor and ran rich. also you could have a air leak like a base gasket head gasket reed gasket or carb boot. if you have a air leak it wiil run rich. 118 is way way to lean. be carful.,
Old Jun 3, 2004 | 10:13 PM
dragracer789's Avatar
hey its acually if you have an air leak the motor will run lean not rich, because there is now alot of air and little gas. no biggie thow, you probly just typed it to fast lol
Anyways my 86 with pipe, 35mm carb, is down to a 130, so dont feel left out.
Old Jun 4, 2004 | 09:31 AM
hancho's Avatar
thanks for the help I orderd a 35mm PWK lastnight
Old Jun 4, 2004 | 05:36 PM
oh yea sorry bout that>[img]i/expressions/face-icon-small-blush.gif[/img]
GregM
Jul 29, 2015 09:41 PM
ghost civic
Jul 27, 2015 03:15 AM
Dustinyoungs
Jul 24, 2015 07:18 AM
Aitch
Jul 21, 2015 09:40 PM
CRamshaw777
Jul 18, 2015 05:46 PM
